[gdal-dev] DWG support in GDAL: some questions
Andrés Maneiro amaneiro at icarto.es
Wed Mar 7 06:52:20 EST 2012
Hi devs,
I have a bunch of DWG archives wich I need to publish with geoserver. I'm
considering to transform them to SHP and then upload them to geoserver.
In order to get support for DWG, should I installed 1.9 version or compiled DWG
support for 1.8 version? If I go for the 1.9 version, has it built-in support
for DWG or should I have to compile it?
For what is worth, I work in Ubuntu 10.10 with GDAL 1.8.
best,
Andrés
