[gdal-dev] OGR Virtual Format for SQLite
Even Rouault even.rouault at mines-paris.org
Sun Mar 11 15:20:39 EDT 2012
Le dimanche 11 mars 2012 16:41:40, gene a écrit :
> Hello, may be a stupid question but I am trying to create a OGR Virtual
> Format file with a SQLite database foo.db3, a table named test and columns
> x, y
> <OGRVRTDataSource>
>     <OGRVRTLayer name="foo">
>         <SrcDataSource
> relativeToVRT="1">SQLITE:database=foo.db3</SrcDataSource>
--> This is not the right syntax to open a sqlite datasource. You just have to
put the filename. No need to prefix it with SQLITE:database=
>         <SrcSQL>select * from test </SrcSQL>
>         <GeometryType>wkbPoint</GeometryType>
>             <LayerSRS>EPSG:31370</LayerSRS>
>         <GeometryField encoding="PointFromColumns" x="x" y="y"/>
>     </OGRVRTLayer>
> </OGRVRTDataSource>
> and it does not work.
> With Oracle, this works
> <OGRVRTDataSource>
>     <OGRVRTLayer name="test">
>         <SrcDataSource>OCI:user/password at server/schema</SrcDataSource>
>         <SrcSQL>select * from test</SrcSQL>
>     </OGRVRTLayer>
> </OGRVRTDataSource>)
> What is the correct syntax for SQLite ?
> http://osgeo-org.1560.n6.nabble.com/OGR-Virtual-Format-for-SQLite-tp456754
> 9p4567549.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
