[gdal-dev] Re: Wrong resolution info from multitable rasterlite
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Mar 13 05:57:18 EDT 2012
Jukka Rahkonen <jukka.rahkonen <at> mmmtike.fi> writes:
> Quantum GIS is placing the map that actually has 100 m pixels in a
> wrong scale into a project. However, I am not sure if this pure
> GDAL error because Spatialite-gis seems to make the same
> error. I can see correct values in the pixel_x_size x and
> pixel_y_size columns in the corresponding raster metadata tables.
This does feel like a GDAL bug. Multitable database that is created with
rasterlite utilities rasterlite_load and rasterlite_pyramid works OK in QGis. I
opened the metadata table of the 100 m pixel raster as a vector layer and I can
see that the polygons presenting the tiles of the pyramid layers (geometry field
in the table) are too wide. It may be gdaladdo that is making the mess but I am
not sure yet.
-Jukka Rahkonen-
