[gdal-dev] Re: Memory leaks in Geo::OGR::Geometry Points() swig Perl function
Ari Jolma ari.jolma at gmail.com
Wed Mar 14 15:47:21 EDT 2012
On 03/14/2012 01:34 PM, Ari Jolma wrote:
> On 03/14/2012 12:59 PM, Ivan Balashov wrote:
>> I appologize that it is memory leak within Points() function.
After some research I conclude that in several cases the returned value
was not made "mortal", i.e., the Perl variables could not be garbage
collected. This was especially the case in methods which returned
arrays, like GetPoint_2D, which is called from within Points.
I've commited a change to trunk that should fix the problem (it does at
least in this case). However, this bug has existed in the bindings from
the beginning.
The changeset is http://trac.osgeo.org/gdal/changeset/24117
Ari
