[gdal-dev] how should SpatialReference::EPSGTreatsAsLatLong work?
Etienne Tourigny etourigny.dev at gmail.com
Thu Mar 15 09:26:12 EDT 2012
The reference for EPSGTreatsAsLatLong  is "This method returns TRUE if
EPSG feels this geographic coordinate system should be treated as
having lat/long coordinate ordering."
However, EPSG 3035 is not a geographic coordinate system, but a
projected one (Lambert Azimuthal Equal Area).
Etienne
On Thu, Mar 15, 2012 at 6:00 AM, Jachym Cepicky
<jachym.cepicky at gmail.com> wrote:
> Hi,
> I'm trying to figure out, how OGRSpatialReference::EPSGTreatAsLatLong is
> supposed to be working -> I'm not able to get any proper result.
> I'm playing with the python interface at this place (and assume, C-api
> would work similar way).
> When I create OGRSpatialReference and import it from EPSG with the code
> 4326, I would say, EPSGTreatAsLatLong should return True:
> from osgeo import osr
> sr = osr.SpatialReference()
> sr.ImportFromEPSG(4326)
> sr.EPSGTreatAsLatLong()
> 0
> Same applies, when trying the same with e.g. EPSG:3035
> sr.ImportFromEPSG(3035)
> 0
> Both do have (accordi ng to http://epsg-registry.org/) north,east axis
> order, so I would asssume EPSGTreatAsLatLong would return True
> Could anybody give me a hint, what am I doing wrong?
> Thanks
> Jachym
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
