[gdal-dev] compiling with FileGeodb API 1.2
Even Rouault even.rouault at mines-paris.org
Thu Mar 15 18:39:09 EDT 2012
Le jeudi 15 mars 2012 23:24:22, Kyle Shannon a écrit :
> Stefano,
> I just built from the trunk with filegdb support and had no issues.  I
> would make sure the 1.1 version is off your system and not anywhere
> configure could find it, then try again.
Kyle,
I've just experienced the same issue as Stefano's. I'm not clear why it works
for you, but ESRI did actually renamed the unix support lib, and GDAL's
configure needs to be updated. Sigh sigh sigh....
Stefano, would you mind opening a ticket about that ?
Even
