[gdal-dev] GdalWarp issue
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Mar 19 15:00:01 EDT 2012
Martin,
Change the resampling method and/or change the SAMPLE_STEPS warp option.
On Tue, Mar 20, 2012 at 12:12 AM, Martin Chapman <chapmanm at pixia.com> wrote:
> All,****
> Please see the attached sub-region screen capture of an image I created
> using gdalwarp 1.9.  I used MS Paint to highlight in red several columns of
> pixels that repeat a pattern from left to right across the image
> (vertically only) where the pixels are the same color for both pixel
> columns when in fact they should be different.  The problem seems to occur
> whether I am going from source wkt (wgs84 in this case) to the same coord
> system or if I go from wgs84 to another coord system.   It only seems to
> happen when the source image is in WGS84 though.****
> Any help is much appreciated.****
> Best regards,****
> Martin****
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120320/b2c96b72/attachment.html
