[gdal-dev] gdalwarp eats scale and offset
Etienne Tourigny etourigny.dev at gmail.com
Wed Mar 21 19:04:39 EDT 2012
I am the author of those changes (adding metadata copy to gdalwarp),
and I must confess I had not thought of scale and offset.
What I did do was add non-conflicting metadata (at the dataset and
band level) and some band-related stuff like description.
I have just tested and gdalwarp does not pass the offset and scale_factor.
Kyle - could you check out trunk and have a look? If you need any
pointers on the new code just ask.
regards,
Etienne
On Wed, Mar 21, 2012 at 7:08 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> On Wed, Mar 21, 2012 at 3:01 PM, Kyle Shannon <ksshannon at gmail.com> wrote:
>> If I have a dataset with a scale and offset:
>> I couldn't find any docs on this. Is this known and/or expected? I would
>> think scale and offset would be transferred to the new file.
> Kyle,
> Scale and offset are basically a form of metadata, and it is ambiguous
> how much metadata gets transferred by processing tasks, like gdalwarp.
> In cases where gdalwarp is being used to warp into an existing output
> file it would not be appropriate to transfer the scale and offset.
> However, in the case that gdalwarp is initializing a new output file
> it would seem reasonable to also copy over the scale and offset.
> I believe some recent changes were made to copy other metadata,
> and this would seem to fall into a similar category.  I'd suggest
> fixing yourself, or writing up a ticket on the topic.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
