[gdal-dev] VRT derived band, pixel functions and Python bindings
Armin Burger armin.burger at gmx.net
Thu Mar 22 14:26:56 EDT 2012
Hi all
I set up 2 pixel functions to be used with VRT images and derived bands.
This works fine with the GDAL utilities and also with MapServer and
Python MapScript.
If I try however to load the pixel functions in GDAL-Python as drivers,
I run into problems. The following code
   from osgeo import gdal
   import os
   os.putenv("GDAL_DRIVER_PATH", "/usr/local/share/gdal/gdalplugins")
   gdal.AllRegister()
produces the error:
python: symbol lookup error: /usr/local/share/gdal/gdalplugins
/gdal_SpotBlue.so: undefined symbol: GDALAddDerivedBandPixelFunc
So is this sort of a bug or is this functionality not available via the
GDAL Python bindings? Environment is Linux, GDAL 1.9, Python 2.6.
Thanks for any help
Armin
