[gdal-dev] Precision about scale/offset element in VRT file
Saâd HESSANE saad.hessane at gmail.com
Fri Mar 23 06:13:53 EDT 2012
Hy all,
The vrt format allow defining the scale and offset element. But the
documentation is not clear about that :
   - *Offset*: This optional element contains the offset that should be
   applied when computing "real" pixel values from scaled pixel values on a
   raster band. The default is 0.0.
   - *Scale*: This optional element contains the scale that should be
   raster band. The default is 1.0.
What that it's mean ? If the value of offset is 1 what that it's change?
And this two elements are use in the *VRTRasterBand* element. What about *
ScaleOffset* and *ScaleRatio* in the *ComplexSource* element?
Thank you.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120323/facd346b/attachment.html
