[gdal-dev] vsicurl
Etienne Tourigny etourigny.dev at gmail.com
Fri Mar 23 16:56:33 EDT 2012
Kyle,
the driver(s) probably need to support "large file API"
>From http://trac.osgeo.org/gdal/wiki/UserDocs/ReadInZip
The fact that this new capability is implemented as virtual file
systems imply that it will only work for GDAL drivers supporting the
"large file API". A non-exhaustive list of such drivers is :
The full list can be obtained by looking at the driver marked with 'v'
when running 'gdalinfo --formats'
for example, netcdf and hdf do not support /vsigzip (and probably not /vsicurl)
Etienne
On Fri, Mar 23, 2012 at 5:31 PM, Kyle Shannon <kyle at pobox.com> wrote:
> What are the requirements for using the vsicurl handler for accessing files?
> Do drivers have to implement anything special do have curl support?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
