[gdal-dev] possible to take this unprojected/unknown coordinate system data and assign it to the second known ones projected/coordinate system
Tue Mar 27 20:50:40 EDT 2012
Derek,
Based on the coordinates it seems clear enough that this
is latitude and longitude in decimal degrees.  Based on the
resolution there is little point in worrying about datum so do
something like:
  gdal_translate -a_srs WGS84 in.tif out.tif
After that you should be able to use gdalwarp to
reproject normally as long as you know the coordinate
system you want to go to.
Best regards,
Frank
On Tue, Mar 27, 2012 at 11:20 AM, jdmorgan <jdmorgan at unca.edu> wrote:
> Hello,
> I was hoping someone in the GDAL community could help me out, as I am stuck
> on a particular issue of dealing with a source dataset (geotiff) that has no
> projection information.  Here are the gdalinfo results on the coordinate
> system:
> Coordinate System is:
> LOCAL_CS[" Geocoding information not available Projection Name = Unknown
> Units = other GeoTIFF Units = other",
>     UNIT["unknown",1]]
> Origin = (-34.100006100000002,28.599823000000001)
> Pixel Size = (0.439998627000000,-0.439998627000000)
> I do know if data is representing the continental USA.  And, I want to get
> it into a projection/coordinate system so that I can overlay it with another
> dataset which already has a coordinate systems and is projected.  Is it
> it to the second known ones projected/coordinate system? Hopfully, this
> question makes sense, and someone can tell me if what I am trying to do is
> even possible.
> Thanks,
> Derek
> Derek @ NEMAC
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
