[gdal-dev] Interpretation of DTED elevation data
Even Rouault even.rouault at mines-paris.org
Wed Mar 28 04:23:18 EDT 2012
Selon AlexRNL <alex.barfety at signalis.com>:
> Hi everyone!
> I have been trying to extract elevation data from a DTED file using GDAL (in
> Java). The file being loaded is of level 0 precision and seems to be correct
> as an import into Global Mapper is rendering the expected result.
> I managed to retrieve the image data but I don't know to transform those
> values into a altitude in meters.
> According to the DTED format specification, the elevation values are
> supposed to be two-bytes integer in meters. But, when using the
> http://www.gdal.org/java/org/gdal/gdal/Band.html#ReadRaster_Direct(int, int,
> int, int, int, int, int, java.nio.ByteBuffer) ReadRaster_Direct method, the
> buffer retrieved is supposed to be composed of Int16 number but when i'm
> converting the raw data (bytes) into a short array i'm getting all sorts of
> value which doesn't make a lot of sense. The range of the elevation is
> spanning from 1 to 65286!
> Is there a conversion that i'm missing? How do I get the meter value from
> the raster returned by GDAL?
You should make sure to request with buf_type = gdalconst.GDT_Int16. Then
iterating the buffer with getShort() should deliver the expected values.
Otherwise use the version of ReadRaster() that accepts a short[]. That will be
simpler to use.
The benefit of using ByteBuffer instead standard Java arrays only appears with
*huge* arrays
> I've been searching for a while but it doesn't seem like anyone has that
> kind of problem...
> Thanks in advance for any information that may help me :)
> Alex.
http://osgeo-org.1560.n6.nabble.com/gdal-dev-Interpretation-of-DTED-elevation-data-tp4663511p4663511.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
