[gdal-dev] Minor problem with the OGR clipping
Wed Mar 28 22:41:04 EDT 2012
Eric,
If you could file a ticket on the issue we can make the "looks like a geometry"
logic more bulletproof.
Best regards,
Frank
On Wed, Mar 28, 2012 at 7:27 PM, Eric Grosso <eric.grosso.os at gmail.com> wrote:
> Hi,
> I was writing a small OGR based script (bash) in order to clip several
> shapefiles at the same time.
> Thus I used this piece of code: ogr2ogr -clipsrc polygon_selection.shp
> output.shp input.shp
> Using it, I had the following error: "FAILURE: Invalid geometry. Must be a
> valid POLYGON or MULTIPOLYGON WKT"
> I checked my polygon_selection.shp file. It was "OGC" valid. Then I checked
> the documentation. Apparently it was correct.
> So I finally decided to check the code and I understood why I had this
> message.
> If the filename of the polygon which is used to do the clipping begins with
> "polygon" or "multipolygon", the code tries to convert
> this argument in WKT.
> Here is an code extract of ogr2ogr.cpp  (same for -clipsrc and -clipdst
> options):
> else if (EQUALN(papszArgv[iArg+1], "POLYGON", 7) ||
> EQUALN(papszArgv[iArg+1], "MULTIPOLYGON", 12))
> I let you decide what to do (add this very minor problem to the
> documentation or change a bit the code,
> e.g. "POLYGON", 7 becomes "POLYGON(", 8 could do the trick). That's why I
> didn't open any bug report or enhancement request.
> First time I write on this list, so I catch the opportunity to thank all the
> developers of GDAL/OGR for your wonderful work.
> Cheers,
> Eric
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
