[gdal-dev] GDAL Tiling
akshay gupta akshaygupta202 at gmail.com
Thu Mar 29 03:40:44 EDT 2012
I am presently using -srcwin for copying AOI to a different file. does
-projwin have any advantage over -srcwin?
Akhy
On Wed, Mar 28, 2012 at 5:29 PM, Jay L. <jzl5325 at psu.edu> wrote:
> Akshay,
> 1) An AOI can be created using the -projwin option in gdal_translate.  You
> can use that option when creating a new raster with a new tiles size.
> 2) Using the Python bindings it is possible to read a segment of a raster
> into memory without allocating memory.  I am unsure using another other
> language.
> Jay
> On Wed, Mar 28, 2012 at 5:16 AM, Mateusz Loskot <mateusz at loskot.net>wrote:
>> On 28 March 2012 07:45, akshay gupta <akshaygupta202 at gmail.com> wrote:
>> > 2) When I read an image through ReadBlock() i had to allocate some
>> memory
>> > and pass it in the function. Is there some way that i get the image data
>> > stored in GDALRasterBlock directly without passing my own allocated
>> memory.
>> http://www.gdal.org/classGDALRasterBlock.html#_details
>> "In normal situations applications do not interact directly
>> with the GDALRasterBlock - instead it it utilized
>> by the RasterIO() interfaces to implement caching"
>> Best regards,
>> Mateusz Loskot, http://mateusz.loskot.net
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120329/ef77ebf5/attachment.html
