[gdal-dev] fail to build gdal 1.9 with minGW
Even Rouault even.rouault at mines-paris.org
Thu Mar 29 04:23:23 EDT 2012
Selon chenliang wang <hi181904665 at msn.com>:
> Thanks for your reply. I have tried 'make clean' and then rebuild GDAL.
> And I have also modified GNUmakefile ,replaed '${GDAL_ROOTs}' for '.'
> and then 'make clean' and rebuild it again. Unfortunately, I failed
> again. I use command ' ./configure --prefix=..... ' Should I need to add
> option '--host=mingw32' or '--without-libtool'?
I have not a mingw environment to test. Is it a compilation problem or a linking
problem ?
> 于 2012-3-29 15:52, Even Rouault 写道:
> > Selon chenliang wang<hi181904665 at msn.com>:
> >> hi:
> >> I failed to build gdal 1.9 with minGW. I modified 'cpl_multiproc.h' with
> >> the patch.But there are still errors with build:cpl_multiproc.cpp:73:
> >> undefined reference to `CPLCreateOrAcquireMutex' .Pls help me out.Thanks!
> >> #if defined(WIN32)&&  !defined(CPL_MULTIPROC_STUB)
> >> # define CPL_MULTIPROC_WIN32
> >> /* MinGW can have pthread support, so disable it to avoid issues */
> >> /* in cpl_multiproc.cpp */
> >> # undef CPL_MULTIPROC_PTHREAD
> >> #endif
> > Did you 'make clean' after applying the patch and before rebuilding GDAL ?
> The
> > reporter of https://trac.osgeo.org/gdal/ticket/4430 confirmed that the
> above
> > patch fixed building for him.
> >> Chen-liang Wang
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
