[gdal-dev] Error in creating gml file
Even Rouault even.rouault at mines-paris.org
Thu Mar 29 16:28:55 EDT 2012
Le jeudi 29 mars 2012 22:03:06, proto83 a écrit :
> ogr2ogr -f "GML" oikismoi_irakliou_gml.gml oikismoi_irakliou.shp
> i write this in the command line and i receive the following message.
> ERROR4:Failed to create GML file oikismoi_irakliou_gml.gml
> GML driver failed to create oikismoi_irakliou_gml.gml
> Does anyone knows what is the problem?
Looking at the code, this error messages really comes from we cannot open a
file in read/write mode on the filesystem. You should check the filesystem
permissions on that directory/file
> Regards,
> Spiros.
> http://osgeo-org.1560.n6.nabble.com/Error-in-creating-gml-file-tp4669016p4
> 669016.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
