[gdal-dev] Re: Error in creating gml file
Salvatore Larosa lrssvtml at gmail.com
Thu Mar 29 16:58:50 EDT 2012
Il giorno gio, 29/03/2012 alle 13.31 -0700, proto83 ha scritto:
> can you explain me more if it's not problem for you? :)
I assume you are on Linux!
What returns this command:
$ ls -l | grep yourFolder
"youFolder" is the folder where you save your files!
