[gdal-dev] Re: Error in creating gml file
Chaitanya kumar CH
chaitanya.ch at gmail.com
Fri Mar 30 10:30:06 EDT 2012
Spiros,
Your command was correct. The error you got was caused because the ogr2ogr
utility could not create a file in the place you specified. See if you can
create a folder or a file in the folder you are trying to save the file
oikismoi_irakliou_gml.gml. If you can't, it means that you don't have
permissions to modify that folder. Try to save the file in some other place.
On Fri, Mar 30, 2012 at 6:54 PM, proto83 <proto83 at hol.gr> wrote:
> Can you give me an example,how will i do it?
> Sorry,but i am a little bit confused.
> http://osgeo-org.1560.n6.nabble.com/Error-in-creating-gml-file-tp4669016p4671308.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120330/d936ce55/attachment-0001.html
