[gdal-dev] Problems with gdal and hdf files
Agustin Lobo alobolistas at gmail.com
Wed May 2 08:43:12 EDT 2012
You are right. I was confusing bands and subdatasets.
The following does not work:
$ gdal_translate -b 4  lndsr.L5169054_05420101216.hdf test.tif
Input file contains subdatasets. Please, select one of them for reading.
The following works:
$ gdal_translate -sds lndsr.L5169054_05420101216.hdf test.tif
which results in test.tif1 to test.tif9 (probably should be test1.tif
to test9.tif)
but there is no way to actually select 1 or more specific subdatasets
The most important
QGIS complains:
Cannot get GDAL raster band:
R (raster) complains
> r <- brick("lndsr.L5169054_05420101216.hdf")
Error in .rasterObjectFromFile(x, objecttype = "RasterBrick", ...) :
  Cannot create a RasterLayer object from this file.
In addition: Warning message:
In .rasterFromGDAL(x, band = band, objecttype, ...) :
  GeoTransform values not available; georeferencing will not be correct
but GDALinfo() is correct.
Cannot test hdf5 or readGDAL() in R as the file is huge
I guess the problem is in QGIS (and R package raster)? I'm not sure,
as I do not know if
subdatasets can be selected for reading using gdal.
Agus
2012/5/2 Even Rouault <even.rouault at mines-paris.org>:
> Selon Agustin Lobo <alobolistas at gmail.com>:
>> Hi!
>> The gdal info of a multiband satellite image in hdf is reported by
>> gdal as "Size is 512, 512"
>> in contradiction with the size of the subdatasets. QGIS and R
>> (raster+rgdal) report an error at opening the file,
>> while envi and HDFLook can open it with no problem. I include the
>> gdalinfo output and the
>> info reported by HDFLook. Any help appreciated.
> I don't consider that to be a problem. The size reported on a GDAL dataset that
> is only made of subdatasets (that is to say when the dataset has no raster bands
> in itself, which is the case here) has no meaning, and is put to a default value
> of 512x512. You have to open the subdatasets to know their size(in the case of
> HDF4, the description of the subdataset also give them). There are cases where
> the subdsatasets have different sizes, so it would be impossible to set a
> significant value for the size of the dataset.
>> Thanks
>> Agus
>> $ gdalinfo --version
>> GDAL 1.8.0, released 2011/01/12
>> $ gdalinfo lndsr.L5169054_05420101216.hdf
>> Driver: HDF4/Hierarchical Data Format Release 4
>> Files: lndsr.L5169054_05420101216.hdf
>> Size is 512, 512
>> Coordinate System is `'
>> Metadata:
>>   DataProvider=UMD
>>   Satellite=LANDSAT_5
>>   Instrument=TM
>>   AcquisitionDate=2010-12-16T00:00:00.000000Z
>>   Level1ProductionDate=2012-02-22T00:00:00.000000Z
>>   SolarZenith=42.02009
>>   SolarAzimuth=141.4236
>>   WRS_System=2
>>   WRS_Path=169
>>   WRS_Row=54
>>   NumberOfBands=6
>>   BandNumbers=1, 2, 3, 4, 5, 7
>>   ShortName=L5TSR
>>   LocalGranuleID=L5TSR.a2010350.w2p169r054.020.2012117105207.hdf
>>   ProductionDate=2012-04-26T10:52:07Z
>>   PGEVersion=1.0.9
>>   ProcessVersion=1.0.4
>>   WestBoundingCoordinate=36.6199876177544
>>   EastBoundingCoordinate=38.780676500528
>>   NorthBoundingCoordinate=9.61826703329522
>>   SouthBoundingCoordinate=7.72285510894074
>>   OrientationAngle=0
>>   PixelSize=30
>>   HDFEOSVersion=HDFEOS_V2.4
>>   Cloud Mask Algo Version=CMReflectanceBasedv1.0
>> Subdatasets:
> SUBDATASET_1_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band1
>>   SUBDATASET_1_DESC=[6961x7901] band1 Grid (16-bit integer)
> SUBDATASET_2_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band2
>>   SUBDATASET_2_DESC=[6961x7901] band2 Grid (16-bit integer)
> SUBDATASET_3_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band3
>>   SUBDATASET_3_DESC=[6961x7901] band3 Grid (16-bit integer)
> SUBDATASET_4_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band4
>>   SUBDATASET_4_DESC=[6961x7901] band4 Grid (16-bit integer)
> SUBDATASET_5_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band5
>>   SUBDATASET_5_DESC=[6961x7901] band5 Grid (16-bit integer)
> SUBDATASET_6_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band7
>>   SUBDATASET_6_DESC=[6961x7901] band7 Grid (16-bit integer)
> SUBDATASET_7_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:atmos_opacity
>>   SUBDATASET_7_DESC=[6961x7901] atmos_opacity Grid (16-bit integer)
> SUBDATASET_8_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:lndsr_QA
>>   SUBDATASET_8_DESC=[6961x7901] lndsr_QA Grid (16-bit integer)
> SUBDATASET_9_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band6
>>   SUBDATASET_9_DESC=[6961x7901] band6 Grid (16-bit integer)
>> Corner Coordinates:
>> Upper Left  (    0.0,    0.0)
>> Lower Left  (    0.0,  512.0)
>> Upper Right (  512.0,    0.0)
>> Lower Right (  512.0,  512.0)
>> Center      (  256.0,  256.0)
>> HDFLooK:
>> Global attributes: 26
>> DataProvider:
> UMDLANDSAT_5TM2010-12-16T00:00:00.000000Z2012-02-22T00:00:00.000000Z    SolarZenith:    42.0201
>>       SolarAzimuth:   141.424
>> 2     WRS_Path:       169
>>       WRS_Row:        54
>>       NumberOfBands:  6
>>       BandNumbers:    1,  2,  3,  4,  5,  7
> L5TSRL5TSR.a2010350.w2p169r054.020.2012117105207.hdf2012-04-26T10:52:07Z1.0.91.0.4      WestBoundingCoordinate: 36.62
>>       EastBoundingCoordinate: 38.7807
>>       NorthBoundingCoordinate:        9.61827
>>       SouthBoundingCoordinate:        7.72286
>>       OrientationAngle:       0
>>       PixelSize:      30
> HDFEOS_V2.4-----------------------------------------------------------------------------------
>> GROUP=SwathStructure
>> END_GROUP=SwathStructure
>> GROUP=GridStructure
>>       GROUP=GRID_1
>>               GridName="Grid"
>>               XDim=7901
>>               YDim=6961
>>               UpperLeftPointMtrs=(238785.000000,1063215.000000)
>>               LowerRightMtrs=(475815.000000,854385.000000)
>>               Projection=GCTP_UTM
>>               ZoneCode=37
>>               SphereCode=12
>>               GridOrigin=HDFE_GD_UL
>>               GROUP=Dimension
>>               END_GROUP=Dimension
>>               GROUP=DataField
>>                       OBJECT=DataField_0
>>                               DataFieldName="band1"
>>                               DataType=DFNT_INT16
>>                               DimList=("YDim","XDim")
>>                       END_OBJECT=DataField_0
>>                       OBJECT=DataField_1
>>                               DataFieldName="band2"
>>                               DataType=DFNT_INT16
>>                       END_OBJECT=DataField_1
>>                       OBJECT=DataField_2
>>                               DataFieldName="band3"
>>                               DataType=DFNT_INT16
>>                       END_OBJECT=DataField_2
>>                       OBJECT=DataField_3
>>                               DataFieldName="band4"
>>                               DataType=DFNT_INT16
>>                       END_OBJECT=DataField_3
>>                       OBJECT=DataField_4
>>                               DataFieldName="band5"
>>                               DataType=DFNT_INT16
>>                       END_OBJECT=DataField_4
>>                       OBJECT=DataField_5
>>                               DataFieldName="band7"
>>                               DataType=DFNT_INT16
>>                       END_OBJECT=DataField_5
>>                       OBJECT=DataField_6
>>                               DataFieldName="atmos_opacity"
>>                               DataType=DFNT_INT16
>>                       END_OBJECT=DataField_6
>>                       OBJECT=DataField_7
>>                               DataFieldName="lndsr_QA"
>>                               DataType=DFNT_INT16
>>                       END_OBJECT=DataField_7
>>                       OBJECT=DataField_9
>>                               DataFieldName="band6"
>>                               DataType=DFNT_INT16
>>                       END_OBJECT=DataField_9
>>               END_GROUP=DataField
>>               GROUP=MergedFields
>>               END_GROUP=MergedFields
>>       END_GROUP=GRID_1
>> END_GROUP=GridStructure
>> GROUP=PointStructure
>> END_GROUP=PointStructure
>> END
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
