[gdal-dev] RFC 39
Peter Halls p.halls at york.ac.uk
Thu May 3 04:27:31 EDT 2012
Ari,
    as a user (and teacher of users), I would urge you to keep to the model
where the output is always a new object (actually the same as ArcGIS),
rather than consider modifying an input for any of these spatial
operations.  That automatically solves the read-only input issue.
Best wishes,
Peter
On 3 May 2012 07:34, Ari Jolma <ari.jolma at gmail.com> wrote:
> On 05/02/2012 09:56 PM, Jason Roberts wrote:
>> Hi Ari,
>> I have been following this proposal with interest. I have a couple of
>> questions; sorry to bring them up late in the RFC process.
>> It looks like the inspiration for this was the Overlay toolset in the
>> ArcGIS
>> geoprocessing toolbox. That is nice for people like me who regularly work
>> with ArcGIS; it increases the possibility of being able to replace
>> automation currently based on ArcGIS with something based on GDAL.
>> Assuming
>> you are aiming for basic parity with ArcGIS:
> ArcGIS is an example which is assumably pretty good, and I'm not aware of
> any standards or better ones so that's the reason. Personally, I don't use
> ArcGIS, so I can't say much.
>> 1. Would you consider implementing a Symmetrical Difference method? It is
>> the only one from the ArcGIS Overlay toolset that you did not implement
>> (except Spatial Join, which does not really apply here).
> I'd be happy to. Can you point me to a description of the method?
>> 2. In ArcGIS, the Intersect and Union tools support multiple inputs. Is
>> that
>> something you would consider implementing? I don't have a strong opinion
>> on
>> this. It is occasionally necessary to use all of these tools with multiple
>> inputs (e.g. erase several layers from a starting layer). I'm not
>> immediately sure why ESRI elected to support multiple inputs for two of
>> their tools but not more of them.
> We've chosen to implement these tools as C = A.method(B), i.e., they
> always produce a result layer and not change A nor B (the C has to be
> created before the actual method). For Update, Clip and Erase it might make
> sense (as the schema of the result layer is only that of input layer) to
> have the method be an in-place method: A.method(B), i.e., change A. Then it
> would be trivial to write
> for all B in (a list of method layers)
>    A.method(B)
> I would in fact support this syntax as it is more versatile and saves
> memory in some cases. The downside is that it does not work with read-only
> data sources and thus is probably not suitable for GDAL.
> In Intersection, Union and Identity the schema of the result may contain
> attributes from the method layer, thus IMO they do not fit so well into the
> in-place syntax.
> In the current syntax, to run a method on several method layers:
>    C = new Layer like A
>    A.method(B, C)
>    delete A
>    A = C
> It really seems to me that this would be practical only for memory layers.
> Maybe the support for multiple layers should be left for the command line
> tool or scripting language layer.
> For example I'll probably build a support into the Perl bindings for the
> in-place syntax.
>> 3. Will these functions be exposed from the Python bindings?
> They are already, if you apply the patch. The test code is written in
> Python.
> Thanks for the interest.
> Ari
>> Best regards,
>> Jason
>> -----Original Message-----
>> From: gdal-dev-bounces at lists.osgeo.**org<gdal-dev-bounces at lists.osgeo.org>
>> [mailto:gdal-dev-bounces@**lists.osgeo.org<gdal-dev-bounces at lists.osgeo.org>]
>> On Behalf Of Ari Jolma
>> Sent: Wednesday, April 25, 2012 9:33 AM
>> To: gdal-dev at lists.osgeo.org
>> Subject: [gdal-dev] RFC 39
>> Folks,
>> I'll start a new thread for this RFC.
>> I've uploaded a new patch, which hopefully corrects the issues Even
>> brought
>> up. Below are comments.
>> I've not added the Append or Buffer methods, which basically work on just
>> one layer. I believe such functionality is simple enough to create using
>> feature iteration.
>> Ari
>> the patch:
>> http://trac.osgeo.org/gdal/**attachment/wiki/rfc39_ogr_**
>> layer_algebra/rfc39.pat<http://trac.osgeo.org/gdal/attachment/wiki/rfc39_ogr_layer_algebra/rfc39.pat>
>> ch
>> On 04/19/2012 02:04 PM, Even Rouault wrote:
>>> http://trac.osgeo.org/gdal/**wiki/rfc39_ogr_layer_algebra<http://trac.osgeo.org/gdal/wiki/rfc39_ogr_layer_algebra>
>>>>  Ari,
>>> I have reviewed your proposal and it looks interesting. Here are my
>>> observations
>>> 1) Argument order. A.Operation(B, C) where C is the target layer
>>> doesn't seem very intuitive, but I'm not sure I have something
>>> fundamentally better to propose. An alternate solution would be to
>>> make the operations static methods, and have
>>> OGRLayer::Operation(output_**layer, input_layer, method_layer) ? I'd
>>> suggest at least to rename B as method_layer and C as result_layer to be
>> more explicit on the role of each argument.
>> I've changed the names to Input, Method and Output. For example the layer
>> object pointers are pLayerInput etc.
>>  2) It would perhaps be prudent to add a char** papszOptions argument as a
>>> provision for future needs.
>> I've added it.
>>  3) I'm wondering if it would not be more appropriate to separate the
>> creation of
>>> fields of the output layer in a separate method that might be called, or
>> not,
>>> before the real operation. For example IdentifyPrepare() for Identity().
>> Of
>>> course this would complicate a bit the implementation of the operation
>> because
>>> it will need to look for which fields exist in the output layer and how
>> the
>>> input and method layer fields map to those fields. But the establishment
>> of the
>>> mapping and the setting of the output feature from the fields of the
>>> input
>> and
>>> method features could be made in common methods
>>>     This way the XXXXXPrepare() would not need to check that
>>> CreateField()
>>> succeeds because XXXX() could work with an output layer with no fields at
>> all.
>>> Checking that there are not fields with same name would not be necessary
>> (in
>>> that case the value from B would override the value from A).
>> I've created a new method into Feature class: SetFieldsFrom, which uses
>> a map. It is similar to SetFrom, which uses a map. (thus the field copy
>> could be optimized into one function)
>> The layer methods now first check the existence of fields in the result
>> layer. If there are fields, it is assumed that that is what the user
>> wants. If there are no fields, a complete set of fields are created for
>> fields in input and method layers (in some cases only input layer). This
>> behavior could later be overridden with options.
>>  4) It would be nice to able to provide a progress callback to get
>>> progress
>>> report (and also being able to interrupt) for such potentially long
>> operations.
>> I agree. I've added these to the API, but I've not yet added the calls.
>> This requires for example the inclusion of gdal.h into ogr_api.h.
>>  5) A few remarks on the implementation itself (only code review, no
>>> actual
>>> testing). You can likely wait for comments from others before heading to
>> fix
>>> them...
>>> a) CreateField() and CreateFeature() return code should be tested and
>> acted
>>> upon. Likely interrupt the whole process ? (not strictly necessary for
>>> CreateField() is you adopt the idea developed in point 3))
>> I've added tests. I've used the "goto done;" style, where done is a
>> label just before the release of used resources and exit from the
>> method. I've tried to be careful to leave no memory leaks.
>>  b) I think there's something wrong with OGRGeometry *Bfilter =
>>> B->GetSpatialFilter(). When you later do
>>> B->SetSpatialFilter(x_geom->**Intersection(Bfilter)), I believe it will
>> destroy
>>> the previous installed filter, and thus Bfilter will point to a garbage
>> object.
>>> You likely need to clone the initial spatial filter (and delete it after
>>> restoring it at the end of the method)
>> Yes. I checked all calls to GetSpatialFilter and now clone the initial
>> one and destroy it at the end.
>>  c) Each time you do a new OGRFeature(), you need do delete it (after the
>> call to
>>> CreateFeature()).
>> They are now deleted.
>>  d) GetGeometryRef() can return NULL (even for spatial layers). Currently
>> it is
>>> never checked, and there are a few places where it is dereferenced.
>> The validity of the geometry is checked. If there is no geometry, the
>> next feature is fetched.
>>  e) Lines like x_geom_diff = x_geom_diff->Difference(y_**geom) (or geom =
>>> geom->Union(y_geom)) will leak the initial x_geom_diff object. You likely
>> need
>>> to do :
>>>        OGRGeometry* x_geom_diff_new = x_geom_diff->Difference(y_**geom);
>>>        delete x_geom_diff;
>>>        x_geom_diff = x_geom_diff_new;
>> Fixed.
>>  f) The object returned by GetNextFeature() should be deleted after use.
>> It is deleted, even if the iteration is continued.
>>  g) You should be careful with SetGeometryDirectly(). You cannot pass
>> directly
>>> the geometry belonging to another feature because this will segfault when
>> you
>>> free the said feature.
>> Fixed
>>  h) Nothing wrong, but calls to UnsetField() are unnecessary for a feature
>> that
>>> was just created and never set before (all the lines z->UnsetField(...) )
>> The unnecessary code is removed.
>> ______________________________**_________________
>> gdal-dev mailing list
>> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
Peter J Halls, GIS Advisor & Team Leader Applications Support and Training,
               Information Directorate, University of York
Telephone: 01904 323806     Fax: 01904 323740
Snail mail: Harry Fairhurst Building, University of York,
                Heslington, York YO10 5DD
This message has the status of a private and personal communication
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120503/09d02a5c/attachment-0001.html
