[gdal-dev] Which formats are just flat binary files plus a header?
Sjur Kolberg Sjur.A.Kolberg at sintef.no
Thu May 3 16:38:20 EDT 2012
Jonathan,
The same also for the IDRISI .rst + .rdc format.
An example header (.rdc) ASCII file looks like below.
The short ref. system item names a file in a library supplied with the IDRISI distribution.
The GDAL Idrisi driver recognises a subset of these
file format : Idrisi Raster A.1
file title  :
data type   : real
file type   : binary
columns     : 130
rows        : 200
ref. system : utm-32n
ref. units  : m
unit dist.  : 1
min. X      : 400000.0000000
max. X      : 530000.0000000
min. Y      : 6660000.0000000
max. Y      : 6860000.0000000
pos'n error : unspecified
resolution  : 1000.0000000
min. value  : 0
max. value  : 0.66993666
display min : 0
display max : 0.66993666
value units : unspecified
value error : unspecified
flag value  : -9999
flag def'n  : Missing data
legend cats : 0
lineage     :
comment     :
Sjur K :-)
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-
> bounces at lists.osgeo.org] On Behalf Of Martin Lambers
> Sent: 3. mai 2012 18:42
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Which formats are just flat binary files plus a
> header?
> Hi Jonathan!
> On Thu, 3 May 2012 10:35:57 -0500, Jonathan Greenberg wrote:
> > I'm working on some parallel processing routines via rgdal and R, but
> > thought this question was better answered here.  I'm trying to find
> > out which raster formats are simply a flat binary file an a header.
> > ENVI is the one that springs to mind.  We're trying to work up which
> > files can be "natively" written as flat binaries where all we have to
> > do after the file is written is setup the correct header.  Thanks!
> GTA is header + flat binary if compression is switched off.
> Martin
> gdal-dev mailing list
