[gdal-dev] Does the OGR driver for IDRISI read AVL+ADC files?
Even Rouault even.rouault at mines-paris.org
Mon May 7 16:21:51 EDT 2012
Le lundi 07 mai 2012 19:54:19, Even Rouault a écrit :
> Le lundi 07 mai 2012 17:58:16, Sjur Kolberg a écrit :
> > Hello,
> > I try to migrate my IDRISI Vector reading routines from in-house
> > functions to OGR, but have problems with attribute values files. Vector
> > data sets which are linked to .mdb databases are read OK, but for data
> > sets having only a simple .avl+.adc pair present, these seem to be
> > ignored, and only the .vct and .vdc files seem to be read.
> > Are .avl and .adc files with the same file title not recognised as a part
> > of the data set? Is there a way to specify that a certain .avl+.adc pair
> > should be read?
> No, there is no support for .avl / .adc yet. It would be helpful if you
> could provide a sample dataset (ideally with .avl, .adc, .vct, .vdc)
I've just added support for .avl / .adc in GDAL trunk, lightly tested from the
samples you've provided. Feedback appreciated. Binary should be available
download from http://vbkto.dyndns.org/sdk/ daily builds . See the -development
packages in the first lines of the first table.
