[gdal-dev] Re: gdal_translate waits at the end of operation
Kyle Shannon kyle at pobox.com
Wed May 9 19:48:25 EDT 2012
More questions?  Can you convert one image into an xyz?  It sounds like you
can.  Are there no errors or warnings?
On Wed, May 9, 2012 at 5:34 PM, kaarigar <kaarigar at gmail.com> wrote:
> Here's the command line:
> gdal_translate -ot Float32 -of XYZ -co "COLUMN_SEPARATOR=," n40w124.tif
> n40w124.xyz
> Kyle Shannon-3 wrote
> > Sounds like your doing something wrong, it shouldn't hang.  Can you share
> > your command line args or a snippet of your batch file?
> > kss
> http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258p4964307.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120509/7108be0c/attachment.html
