[gdal-dev] Re: gdal_translate waits at the end of operation
kaarigar kaarigar at gmail.com
Wed May 9 20:17:58 EDT 2012
I can convert a single image to XYZ from command line. And can also convert
multiple images to command line via batch file - if I press CTRL-C after the
conversion for one file is 100% done - it will continue to the next file.
There are no errors or warnings. The conversion to XYZ is successful. I have
also tried this on Windows 7 32bit - and found the same problem there too.
Kyle Shannon-3 wrote
> More questions?  Can you convert one image into an xyz?  It sounds like
> you
> can.  Are there no errors or warnings?
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258p4964362.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
