[gdal-dev] Re: gdal_translate waits at the end of operation
kaarigar kaarigar at gmail.com
Thu May 10 11:30:46 EDT 2012
Etienne Tourigny-3 wrote
> Something that is not apparent is that gdal_translate (via driver's
> GDALCreateCopy()) usually opens the new dataset after creation, and
> the XYZ file loading is slow:
That explains it - the XYZ file created is ~4gb in size - it would take it a
very very long time to figure out the details from it. What I don't
understand is why gdal_translate would want to open the created xyz file? Is
there a special build of this utility that doesn't do this?
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258p4965947.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
