[gdal-dev] Re: gdal_translate waits at the end of operation
Thu May 10 11:56:28 EDT 2012
Folks,
I have discovered Even already implemented my idea for XYZ and AAIGRID
19 months ago.  Based on that I don't know why you are seeing a large
wait on closing.
  http://trac.osgeo.org/gdal/changeset/20770/trunk/gdal/frmts/xyz
hmm, I see a reference to 1.9dev - perhaps that was an old 1.9 pre-release
version that predated the above change?  Perhaps you just need to update.
Best regards,
Frank
On Thu, May 10, 2012 at 8:49 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> It should be possible to specially implement the CreateCopy for XYZ
> format to avoid this.  I'll investigate this.
> Best regards,
> On Thu, May 10, 2012 at 8:30 AM, kaarigar <kaarigar at gmail.com> wrote:
>> Etienne Tourigny-3 wrote
>>> Something that is not apparent is that gdal_translate (via driver's
>>> GDALCreateCopy()) usually opens the new dataset after creation, and
>>> the XYZ file loading is slow:
>> That explains it - the XYZ file created is ~4gb in size - it would take it a
>> very very long time to figure out the details from it. What I don't
>> understand is why gdal_translate would want to open the created xyz file? Is
>> there a special build of this utility that doesn't do this?
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258p4965947.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
