[gdal-dev] Re: gdal_translate waits at the end of operation
Thu May 10 12:06:56 EDT 2012
Ah, I see I misunderstood what Even's change was doing.  I'll work on this.
On Thu, May 10, 2012 at 8:56 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Folks,
> I have discovered Even already implemented my idea for XYZ and AAIGRID
> 19 months ago.  Based on that I don't know why you are seeing a large
> wait on closing.
>  http://trac.osgeo.org/gdal/changeset/20770/trunk/gdal/frmts/xyz
> hmm, I see a reference to 1.9dev - perhaps that was an old 1.9 pre-release
> version that predated the above change?  Perhaps you just need to update.
> Best regards,
> Frank
> On Thu, May 10, 2012 at 8:49 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
>> It should be possible to specially implement the CreateCopy for XYZ
>> format to avoid this.  I'll investigate this.
>> Best regards,
>> On Thu, May 10, 2012 at 8:30 AM, kaarigar <kaarigar at gmail.com> wrote:
>>> Etienne Tourigny-3 wrote
>>>> Something that is not apparent is that gdal_translate (via driver's
>>>> GDALCreateCopy()) usually opens the new dataset after creation, and
>>>> the XYZ file loading is slow:
>>> That explains it - the XYZ file created is ~4gb in size - it would take it a
>>> very very long time to figure out the details from it. What I don't
>>> understand is why gdal_translate would want to open the created xyz file? Is
>>> there a special build of this utility that doesn't do this?
>>> View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258p4965947.html
>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | Geospatial Software Developer
