[gdal-dev] Re: gdal_translate waits at the end of operation
Thu May 10 12:32:36 EDT 2012
OK, I have reworked the xyz driver a bit.  The change is at:
  http://trac.osgeo.org/gdal/changeset/24402
It should be possible to retrofit the driver into older version.  Code at:
  http://svn.osgeo.org/gdal/trunk/gdal/frmts/xyz/xyzdataset.cpp
Best regards,
On Thu, May 10, 2012 at 9:06 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Ah, I see I misunderstood what Even's change was doing.  I'll work on this.
> On Thu, May 10, 2012 at 8:56 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
>> Folks,
>> I have discovered Even already implemented my idea for XYZ and AAIGRID
>> 19 months ago.  Based on that I don't know why you are seeing a large
>> wait on closing.
>>  http://trac.osgeo.org/gdal/changeset/20770/trunk/gdal/frmts/xyz
>> hmm, I see a reference to 1.9dev - perhaps that was an old 1.9 pre-release
>> version that predated the above change?  Perhaps you just need to update.
>> Best regards,
>> Frank
>> On Thu, May 10, 2012 at 8:49 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
>>> It should be possible to specially implement the CreateCopy for XYZ
>>> format to avoid this.  I'll investigate this.
>>> Best regards,
>>> On Thu, May 10, 2012 at 8:30 AM, kaarigar <kaarigar at gmail.com> wrote:
>>>> Etienne Tourigny-3 wrote
>>>>> Something that is not apparent is that gdal_translate (via driver's
>>>>> GDALCreateCopy()) usually opens the new dataset after creation, and
>>>>> the XYZ file loading is slow:
>>>> That explains it - the XYZ file created is ~4gb in size - it would take it a
>>>> very very long time to figure out the details from it. What I don't
>>>> understand is why gdal_translate would want to open the created xyz file? Is
>>>> there a special build of this utility that doesn't do this?
>>>> View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258p4965947.html
>>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>> and watch the world go round - Rush    | Geospatial Software Developer
