[gdal-dev] Re: gdal_translate waits at the end of operation
Kyle Shannon KShannon at gcs-research.com
Thu May 10 13:31:55 EDT 2012
Kaarigar,
You can pick up new binaries tomorrow at:
gisinternals.com/sdk
I don't know at exactly what time the packages get built, but they are built daily.
kss
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
Sent: Thursday, May 10, 2012 11:17 AM
To: kaarigar at gmail.com
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Re: gdal_translate waits at the end of operation
On Thu, May 10, 2012 at 9:59 AM, Karu Kaarigar <kaarigar at gmail.com> wrote:
> Thanks, Frank. I am not familiar with the gdal development at all. But
> I think replacing the driver binary with this new one wit your change
> should fix the behavior locally for me?
> Kaarigar
Kaarigar,
The XYZ driver is not built as a distinct driver.  It is just built into the main GDAL .so/.dll.  If you are using pre-built binaries i may be hard to incorporate the change.  If you are building from source, just replace the xyzdataset.cpp file.
In any event, you can just run with the gdal_translate you have now.  It will just be inefficient.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com light and sound - activate the windows | http://pobox.com/~warmerdam and watch the world go round - Rush    | Geospatial Software Developer _______________________________________________
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
