[gdal-dev] Creating a VRT dataset from overviews in C++
Thomas Sevaldrud thomas at silentwings.no
Thu May 10 15:16:23 EDT 2012
Hi Dmitry, and thanks for your answer!
I was actually looking at this patch earlier today, but I also wanted to
see if I could solve it without patching.
Will this patch be included in the official source?
Is it possible to do it the way I described in the previous mail?
Cheers,
Thomas
On Thu, May 10, 2012 at 7:11 PM, Dmitry Baryshnikov <polimax at mail.ru> wrote:
>  10.05.2012 19:03, tseval написал:
> Hi,
> I'm trying to cut and reproject a large image with overviews using the c++
> api. This runs extremely slow when I produce highly downsampled cutouts
> covering large areas of the original image.
> I understand the the Warp API doesn't use the overviews when resampling, so
> I wanted to make a temporary dataset from one of the downscaled overviews
> and do the warping on this dataset instead.
> First of all, is this a sensible way of doing things? If so, what driver
> should I use? I guess VRT? I have been trying to create a VRT by doing
> something like this:
> 	double scaleX = (double)ovrW/origW;
> 	double scaleY = (double)ovrH/origH;
> 	GDALDataset* vrtDS = vrtDriver->Create("", ovrW, ovrH, _numBands,
> _dataType, NULL);
> 	GDALSetProjection(vrtDS, _srcProjectionWKT);
> 	double geoTransform[6];
> 	srcDS->GetGeoTransform(geoTransform);
> 	geoTransform[XFM_PIXEL_SIZE_EW] = scaleX*geoTransform[XFM_PIXEL_SIZE_EW];
> 	geoTransform[XFM_PIXEL_SIZE_NS] = scaleY*geoTransform[XFM_PIXEL_SIZE_NS];
> 	vrtDS->SetGeoTransform(geoTransform);
> But how am I supposed to set the bands in the VRT from the downscaled
> overview bands in the original image?
> Any help on this would be greatly appreciated :)
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Creating-a-VRT-dataset-from-overviews-in-C-tp4965891.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
>  Hi,
> You can try to use this patch to enable overviews in VRT
> http://trac.osgeo.org/gdal/ticket/2076
> or waits as I accomplish my work on fixing this situation.
> <http://trac.osgeo.org/gdal/ticket/2076>
> Best regards,
>     Dmitry
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120510/56f7d503/attachment.html
