[gdal-dev] Batch Processing for gdal_calc.py
Swapnil Chaudhari swapsslan at gmail.com
Fri May 11 00:29:30 EDT 2012
Dear All,
I would like to get your advise on running gdal_calc using shell.
I am finding it difficult, mostly because the command requires you to
define what  -A stands for etc. which is quite different from
gdal_translate or such similar tools, so is the case with Raster
package in R.
I wish to scale all the temperature ascii grids that I have for quite
a few number of folders.
I wrote following sh file
for f in *.tif
do
  echo "Processing $f"
  gdal_calc -A $f --outfile=$f_scaled.asc --calc=A/10
done
However, I am making a mistake somewhere, it does not read above
script as a command. I wish to divide all the rasters with 10 and also
equally wish to make all output files extent as "-projwin -180.0 90.0
180.0 -60.0" and column 720 with rows 300
I would be really thankful if you can give some suggestion on this.
Thanks a ton.
Swapnil Chaudhari
  o__
 _> /__
(_) \(_)....... live healthy
