[gdal-dev] WFS - OGRLayer GetNextFeature - fails
Odd Ragnar Lydersen Odd-Ragnar.Lydersen at powel.no
Mon May 14 02:12:04 EDT 2012
Yes, the server is accessible to the outside world.
But first I must say, that we have modified our server to send the correct gml document.
The problem was that the server only got the < text/xml > part specified by the OutputFormat parameter, and not the < subtype=gml/3.1.1 > part, so our server bailed out.
Then we ran into another problem, when we used OGRLayer. SetSpatialFilterRect()
Our server received a filter which is deprecated in version 1.1.0. , so that we now need to be backwards compatible with version 1.0.0, or so the guy making our server says.
I'll get some more detailed info from him when he gets back 16.05
You can have a go if you like and test it:
http://titest01.powel.no/GeminiMapServer/GeminiVADemo.wfs?service=WFS&version=1.1.0
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: 13. mai 2012 22:31
Is this a server accessible from the outside so I can give a try ?
