[gdal-dev] Re: python SetCacheMax, GetCacheMax
Even Rouault even.rouault at mines-paris.org
Mon May 14 13:56:53 EDT 2012
Le lundi 14 mai 2012 19:16:25, Matt Gregory a écrit :
> On 5/11/2012 4:55 PM, Gregory, Matthew wrote:
> > Hi all,
> > Probably a newbie question.  I'm trying to investigate some read rates
without the benefit of caching from Python.  When I do this:
> >    from osgeo import gdal
> >    gdal.SetCacheMax(0)
> >    print gdal.GetCacheMax()
> > I always get the environment variable value GDAL_CACHE_MAX instead of 0.
> > Throughout my test script, I can also query gdal.GetCacheUsed() and it
> > increases toward GDAL_CACHE_MAX.  Am I totally misunderstanding their
> > use?  I'm on Windows 7 64-bit, GDAL version 1.7.
> A bit more experimentation led to this:
> 786432000
>  >>> gdal.SetCacheMax(0)
> 0
> So, for some reason a call to GetCacheMax has to occur before
> SetCacheMax can be used?  This seems to be working in my testing script.
Not a good reason actually. The workaround you've found is actually what is
needed without the fix I've committed in trunk (
http://trac.osgeo.org/gdal/changeset/24412 )
> matt
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
