[gdal-dev] troubles building trunk on OSX + Xcode 4.3
William Kyngesburye woklist at kyngchaos.com
Wed May 16 10:08:24 EDT 2012
On May 16, 2012, at 8:50 AM, William Kyngesburye wrote:
>> I didn't mentioned explicitly but I did a svn update so the code should be very close to what's in 1.9.1rc
>> Anyone building the release candidate on OSX with XCode 4.3.2 successfully?
>> Joaquim
> 1.9.1rc compiles with no problems (quick-n-dirty, no extras).
> I just noticed something else, but I don't know if it's a problem - your libtool command has a "--tag=LD" flag in it, mine doesn't not.  You also get that message about ignoring unknown tag, and I wonder if it somehow confuses libtool so that it drops the g++.  What is your configure command?
Wait, I found the problem, nothing to do with your configure.
In trunk, --tag=LD was added to GDALMake.opt.in, but it's not in 1.9.1rc1.  When I added that flag to 1.9.1rc, it failed the same as for you.  I'll reopen the bug that prompted adding that flag.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
