[gdal-dev] gdalwarp question
Billy Newman newmanw10 at gmail.com
Wed May 16 10:13:06 EDT 2012
 If I do not provide a source spatial reference to gdalwarp will the
information in the geotiff be used instead?  ie. gdalwarp -t_srs
'EPSG:4326' input.tif output.tif?
I do not have a real example because I do not have the file I am working
with on this computer.  But an example gdalinfo would be:
PROJCS["NAD27 / UTM zone 11N",
    GEOGCS["NAD27",
        DATUM["North_American_Datum_1927",
            SPHEROID["Clarke 1866",6378206.4,294.978698213901]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-117],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1]]
So would my above example work when trying to convert this projection to
EPSG:4326, or do I need to specify the source spatial reference and/or
other parameters.
Thanks
Billy
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120516/3e8dd2d0/attachment.html
