[gdal-dev] JPEG 2000 layers GDAL
Jayesh Chaudhary aashishcy at gmail.com
Thu May 17 16:43:55 EDT 2012
Thanks Even.
I realised that I was using OpenJPEG driver (some old version) which does
not support overviews. I intend to use MrSID which worked as expected.
Thanks a lot.
On Thu, May 17, 2012 at 2:09 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Le jeudi 17 mai 2012 20:04:30, Jayesh Chaudhary a écrit :
> > Folks,
> > I have written a GDAl based reader and I am trying to read JPEG 2000
> > images. When I ran gdalinfo on one of the samples images from here:
> > http://www.openjpeg.org/index.php?menu=samples, it does not list
> subdataset
> > or overviews ( I was expecting overviews ).
> There are no concept of subdataset with JPEG2000 drivers, so this is
> expected.
> As far as overviews, it depends on the particular JPEG2000 driver that you
> uses. JP2ECW, JP2MrSID and JP2KAK should expose them. (JP2ECW exposes
> arbitrary overviews). But JP2OpenJPEG or JPEG2000 (Jasper based) drivers
> aren't sufficiently advanced to expose overviews.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120517/f8635900/attachment.html
