[gdal-dev] VRT with attribute filter?
Even Rouault even.rouault at mines-paris.org
Fri May 18 11:44:32 EDT 2012
Le vendredi 18 mai 2012 17:33:50, Tyler Mitchell a écrit :
> Thanks I'll check that out.
> I'm mainly using the VRT in QGIS against Ingres database.  QGIS isn't doing
> filtering properly for me, (even with passthrough=true) so I'm trying to
> discern whether it's a deficiency of our Ingres driver or if the
> functionality just doesn't exist yet elsewhere :)
Hum, while grepping in QGIS code, I see it doesn't use the
OGR_L_SetAttributeFilter() API, so it must do the filtering on its side.
If you want to know if it is a QGIS or OGR issue, you can try ogrinfo your.vrt
-where "xxxx"
