[gdal-dev] Help with GDAL and HDF4 MODIS data
Etienne Tourigny etourigny.dev at gmail.com
Fri May 18 13:07:36 EDT 2012
I can confirm the bug on linux 64bit.  Please file a bug report and
attach a small dataset (<1MB) or whith the link you sent in your
second mail.
I suspect that the gdal hdf4 driver does not handle something spedific
in this hdf-eos dataset.
On Fri, May 18, 2012 at 12:54 PM, Christopher Mutel <cmutel at gmail.com> wrote:
> Dear all-
> I am having trouble reading a HDF4 dataset using GDAL 1.9.0. The
> datasets I am want to process come from the MODIS evapotranspiration
> project (http://www.ntsg.umt.edu/project/mod16), and can be understood
> correctly in e.g. HDFlook
> (http://www-loa.univ-lille1.fr/Hdflook/hdflook_gb.html). They look
> something like this:
> http://imgur.com/nw7ts
> The problem is that when GDAL opens a subdataset (any of the 4
> possible ones), the resulting image data
> http://imgur.com/fILW2
> This effect happens using gdal_translate and the python bindings to
> write the raw array data directly to a file. Basically, the lower
> third of the image is fine; the next half of the image is masked
> (given the nodata value); and the upper fifth, more peculiarly, has a
> another section of the image repeated several times.
> I am using GDAL 1.9.0 installed through MacPorts. The supported
> formats are listed below. The gdalinfo output is also below.
> My questions are:
> 1. Has anyone else experienced something like this? Is this fixable by
> overriding some metadata in the gdal commands, or doing some other
> transform?
> 2. Could this be related to the fact that I have NetCDF support enabled?
> See e.g.
> http://trac.osgeo.org/gdal/wiki/NetCDF
> http://trac.osgeo.org/gdal/ticket/3957
not at all, the hdf4 driver is opening the file and the netcdf does
not interfere:
Driver: HDF4Image/HDF4 Dataset
That bug report is about building gdal with hdf4 and netcdf (no one
else has confirmed that problem), not about using hdf4 and netcdf
drivers.
> Any help would be greatly appreciated,
> Yours,
> Chris
> Supported Formats:
>  GRASS (ro): GRASS Database Rasters (5.7+)
>  VRT (rw+v): Virtual Raster
>  GTiff (rw+v): GeoTIFF
>  NITF (rw+v): National Imagery Transmission Format
>  RPFTOC (rov): Raster Product Format TOC format
>  ECRGTOC (rov): ECRG TOC format
>  HFA (rw+v): Erdas Imagine Images (.img)
>  SAR_CEOS (rov): CEOS SAR Image
>  CEOS (rov): CEOS Image
>  JAXAPALSAR (rov): JAXA PALSAR Product Reader (Level 1.1/1.5)
>  GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
>  ELAS (rw+v): ELAS
>  AIG (rov): Arc/Info Binary Grid
>  AAIGrid (rwv): Arc/Info ASCII Grid
>  GRASSASCIIGrid (rov): GRASS ASCII Grid
>  SDTS (rov): SDTS Raster
>  DTED (rwv): DTED Elevation Raster
>  PNG (rwv): Portable Network Graphics
>  JPEG (rwv): JPEG JFIF
>  MEM (rw+): In Memory Raster
>  JDEM (rov): Japanese DEM (.mem)
>  GIF (rwv): Graphics Interchange Format (.gif)
>  BIGGIF (rov): Graphics Interchange Format (.gif)
>  ESAT (ro): Envisat Image Format
>  XPM (rwv): X11 PixMap Format
>  BMP (rw+v): MS Windows Device Independent Bitmap
>  DIMAP (rov): SPOT DIMAP
>  AirSAR (ro): AirSAR Polarimetric Image
>  RS2 (ro): RadarSat 2 XML Product
>  PCIDSK (rw+v): PCIDSK Database File
>  ILWIS (rw+v): ILWIS Raster Map
>  SGI (rw+): SGI Image File Format 1.0
>  SRTMHGT (rwv): SRTMHGT File Format
>  Leveller (rw+): Leveller heightfield
>  Terragen (rw+): Terragen heightfield
>  GMT (rw): GMT NetCDF Grid Format
>  netCDF (rw+): Network Common Data Format
>  HDF4 (ro): Hierarchical Data Format Release 4
>  HDF4Image (rw+): HDF4 Dataset
>  ISIS3 (rov): USGS Astrogeology ISIS cube (Version 3)
>  ISIS2 (rw+v): USGS Astrogeology ISIS cube (Version 2)
>  PDS (rov): NASA Planetary Data System
>  TIL (rov): EarthWatch .TIL
>  ERS (rw+v): ERMapper .ers Labelled
>  L1B (rov): NOAA Polar Orbiter Level 1b Data Set
>  FIT (rwv): FIT Image
>  RMF (rw+v): Raster Matrix Format
>  WCS (rov): OGC Web Coverage Service
>  WMS (rwv): OGC Web Map Service
>  MSGN (ro): EUMETSAT Archive native (.nat)
>  RST (rw+v): Idrisi Raster A.1
>  INGR (rw+v): Intergraph Raster
>  GSAG (rwv): Golden Software ASCII Grid (.grd)
>  GSBG (rw+v): Golden Software Binary Grid (.grd)
>  GS7BG (rov): Golden Software 7 Binary Grid (.grd)
>  COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
>  TSX (rov): TerraSAR-X Product
>  COASP (ro): DRDC COASP SAR Processor Raster
>  R (rwv): R Object Data Store
>  PNM (rw+v): Portable Pixmap Format (netpbm)
>  DOQ1 (rov): USGS DOQ (Old Style)
>  DOQ2 (rov): USGS DOQ (New Style)
>  ENVI (rw+v): ENVI .hdr Labelled
>  EHdr (rw+v): ESRI .hdr Labelled
>  GenBin (rov): Generic Binary (.hdr Labelled)
>  PAux (rw+): PCI .aux Labelled
>  MFF (rw+): Vexcel MFF Raster
>  MFF2 (rw+): Vexcel MFF2 (HKV) Raster
>  FujiBAS (ro): Fuji BAS Scanner Image
>  GSC (rov): GSC Geogrid
>  FAST (rov): EOSAT FAST Format
>  BT (rw+v): VTP .bt (Binary Terrain) 1.3 Format
>  LAN (rw+v): Erdas .LAN/.GIS
>  CPG (ro): Convair PolGASP
>  IDA (rw+): Image Data and Analysis
>  NDF (rov): NLAPS Data Format
>  EIR (rov): Erdas Imagine Raw
>  DIPEx (rov): DIPEx
>  LCP (rov): FARSITE v.4 Landscape File (.lcp)
>  GTX (rw+v): NOAA Vertical Datum .GTX
>  LOSLAS (rov): NADCON .los/.las Datum Grid Shift
>  NTv2 (rw+v): NTv2 Datum Grid Shift
>  ACE2 (rov): ACE2
>  SNODAS (rov): Snow Data Assimilation System
>  RIK (ro): Swedish Grid RIK (.rik)
>  USGSDEM (rwv): USGS Optional ASCII DEM (and CDED)
>  GXF (ro): GeoSoft Grid Exchange Format
>  HTTP (ro): HTTP Fetching Wrapper
>  BAG (ro): Bathymetry Attributed Grid
>  HDF5 (ro): Hierarchical Data Format Release 5
>  HDF5Image (ro): HDF5 Dataset
>  NWT_GRD (rov): Northwood Numeric Grid Format .grd/.tab
>  NWT_GRC (rov): Northwood Classified Grid Format .grc/.tab
>  ADRG (rw+v): ARC Digitized Raster Graphics
>  SRP (rov): Standard Raster Product (ASRP/USRP)
>  BLX (rw): Magellan topo (.blx)
>  PostGISRaster (ro): PostGIS Raster driver
>  SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
>  KMLSUPEROVERLAY (rwv): Kml Super Overlay
>  XYZ (rwv): ASCII Gridded XYZ
>  HF2 (rwv): HF2/HFZ heightfield raster
>  OZI (rov): OziExplorer Image File
>  CTG (rov): USGS LULC Composite Theme Grid
>  E00GRID (rov): Arc/Info Export E00 GRID
>  ZMap (rwv): ZMap Plus Grid
>  NGSGEOID (rov): NOAA NGS Geoid Height Grids
> gdalinfo
> Files: none associated
> Size is 1200, 1200
> Coordinate System is:
> PROJCS["unnamed",
>    GEOGCS["Unknown datum based upon the custom spheroid",
>        DATUM["Not specified (based on custom spheroid)",
>            SPHEROID["Custom spheroid",6371007.181,0]],
>        PRIMEM["Greenwich",0],
>        UNIT["degree",0.0174532925199433]],
>    PROJECTION["Sinusoidal"],
>    PARAMETER["longitude_of_center",0],
>    PARAMETER["false_easting",0],
>    PARAMETER["false_northing",0],
>    UNIT["Meter",1]]
> Origin = (-6671703.117999999783933,-3335851.558999999891967)
> Pixel Size = (926.625433055833014,-926.625433055833355)
> Metadata:
>  _FillValue=32767
>  add_offset=0
>  add_offset_err=0
>  Affi.=NTSG, School of Forestry, U. of MT
>  ALGORITHMPACKAGEACCEPTANCEDATE=10-01-2004
>  ALGORITHMPACKAGEMATURITYCODE=Normal
>  ALGORITHMPACKAGENAME=MODPR_15A2
>  ALGORITHMPACKAGEVERSION=5
>  ASSOCIATEDINSTRUMENTSHORTNAME=MODIS
>  ASSOCIATEDPLATFORMSHORTNAME=Terra
>  ASSOCIATEDSENSORSHORTNAME=MODIS
>  AUTOMATICQUALITYFLAG=Passed
>  AUTOMATICQUALITYFLAGEXPLANATION=No automatic quality assessment is
> performed in the PGE
>  calibrated_nt=22
>  CHARACTERISTICBINANGULARSIZE=30.0
>  CHARACTERISTICBINSIZE=926.625433055556
>  DATACOLUMNS=1200
>  DATAROWS=1200
>  DAYNIGHTFLAG=Day
>  DESCRREVISION=5.0
>  EASTBOUNDINGCOORDINATE=-57.7254044077251
>  Email=qiaozhen at ntsg.umt.edu
>  EXCLUSIONGRINGFLAG=N
>  GEOANYABNORMAL=False
>  GEOESTMAXRMSERROR=50.0
>  GLOBALGRIDCOLUMNS=43200
>  GLOBALGRIDROWS=21600
>  GRANULEBEGINNINGDATETIME=2006-12-11T09:38:17.000Z
>  GRANULEDAYNIGHTFLAG=Day
>  GRANULEENDINGDATETIME=2006-12-11T09:38:17.000Z
>  GRINGPOINTLATITUDE=-39.9999999964079, -29.8506269556485,
> -29.8879227550404, -40.0438107454138
>  GRINGPOINTLONGITUDE=-78.3244373487826, -69.2295648918179,
> -57.4987926415755, -65.0468184138665
>  GRINGPOINTSEQUENCENO=1, 2, 3, 4
>  HDF-EOS file name=MOD16A2.A2000M01.h12v12.105.2010357170459.hdf
>  HDFEOSVersion=HDFEOS_V2.16
>  HORIZONTALTILENUMBER=12
>  INPUTPOINTER=MOD15A1.A2001008.h12v12.005.2006348070239.hdf,
> MOD15A1.A2001007.h12v12.005.2006348001835.hdf,
> MOD15A1.A2001006.h12v12.005.2006347202242.hdf,
> MOD15A1.A2001005.h12v12.005.2006347152227.hdf,
> MOD15A1.A2001004.h12v12.005.2006347093732.hdf,
> MOD15A1.A2001003.h12v12.005.2006346135836.hdf,
> MOD15A1.A2001002.h12v12.005.2006345172013.hdf,
> MOD15A1.A2001001.h12v12.005.2006345093817.hdf, MOD15A2_ANC_RI4.hdf
>  LOCALGRANULEID=MOD15A2.A2001001.h12v12.005.2006351105708.hdf
>  LOCALVERSIONID=5.0.3
>  long_name=MOD16A2 -- MODIS Gridded 1KM monthly Composite potential
> Evapotranspiration (ET)
>  LONGNAME=MODIS/Terra Leaf Area Index/FPAR 8-Day L4 Global 1km SIN Grid
>  Maker=Qiaozhen Mu
>  MAXIMUMOBSERVATIONS=1
>  MOD16 version=UM_collection5
>  NADIRDATARESOLUTION=1km
>  NDAYS_COMPOSITED=8
>  NORTHBOUNDINGCOORDINATE=-29.9999999973059
>  NUMBEROFGRANULES=1
>  PARAMETERNAME=MOD15A2
>  PGEVERSION=5.0.5
>  PROCESSINGCENTER=MODAPS
>  PROCESSINGENVIRONMENT=IRIX64 mtvs3 6.5 10070055 IP35
>  PRODUCTIONDATETIME=2006-12-17T10:57:08.000Z
>  QAPERCENTCLOUDCOVER=5
>  QAPERCENTEMPIRICALMODEL=2
>  QAPERCENTGOODFPAR=98
>  QAPERCENTGOODLAI=98
>  QAPERCENTGOODQUALITY=98
>  QAPERCENTINTERPOLATEDDATA=0
>  QAPERCENTMAINMETHOD=98
>  QAPERCENTMISSINGDATA=17
>  QAPERCENTOTHERQUALITY=100
>  QAPERCENTOUTOFBOUNDSDATA=17
>  RANGEBEGINNINGDATE=2001-01-01
>  RANGEBEGINNINGTIME=00:00:00
>  RANGEENDINGDATE=2001-01-08
>  RANGEENDINGTIME=23:59:59
>  REPROCESSINGACTUAL=reprocessed
>  REPROCESSINGPLANNED=further update is anticipated
>  scale_factor=0.1
>  scale_factor_err=0
>  SCIENCEQUALITYFLAG=Not Investigated
>  SCIENCEQUALITYFLAGEXPLANATION=See
> http://landweb.nascom/nasa.gov/cgi-bin/QA_WWW/qaFlagPage.cgi?sat=terra
> the product Science Quality status.
>  SHORTNAME=MOD15A2
>  SOUTHBOUNDINGCOORDINATE=-39.9999999964079
>  SPSOPARAMETERS=5367, 2680
>  SYSTEMFILENAME=MOD15A1.A2001008.h12v12.005.2006348070239.hdf,
>  TileID=51012012
>  units=kg/m^2/mon
>  valid_range=-32767, 32700
>  VERSIONID=5
>  VERTICALTILENUMBER=12
>  Webpage=http://www.ntsg.umt.edu
>  WESTBOUNDINGCOORDINATE=-78.3244373487825
> Corner Coordinates:
> Upper Left  (-6671703.118,-3335851.559) ( 69d16'55.32"W, 30d 0' 0.00"S)
> Lower Left  (-6671703.118,-4447802.079) ( 78d19'27.97"W, 40d 0' 0.00"S)
> Upper Right (-5559752.598,-3335851.559) ( 57d44' 6.10"W, 30d 0' 0.00"S)
> Lower Right (-5559752.598,-4447802.079) ( 65d16'13.31"W, 40d 0' 0.00"S)
> Center      (-6115727.858,-3891826.819) ( 67d 8'33.37"W, 35d 0' 0.00"S)
> Band 1 Block=1200x833 Type=Int16, ColorInterp=Gray
>  Description = MOD16A2 -- MODIS Gridded 1KM monthly Composite
> potential Evapotranspiration (ET)
>  NoData Value=32767
>  Unit Type: kg/m^2/mon
>  Offset: 0,   Scale:0.1
> Chris Mutel
> Ökologisches Systemdesign - Ecological Systems Design
> Institut f.Umweltingenieurwissenschaften - Institute for Environmental
> Engineering
> ETH Zürich - HIF C 44 - Schafmattstr. 6
> 8093 Zürich
> Telefon: +41 44 633 71 45 - Fax: +41 44 633 10 61
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
