[gdal-dev] Upgraded to 1.9 - Python Bindings Error
Marius Jigmond mariusjigmond at hotmail.com
Sun May 20 00:32:47 EDT 2012
On 05/04/2012 08:16 PM, Jay L. wrote:
> List,
> Just upgraded to 1.9.0 on my windows 7 machine and I can no longer
> access gdal via the python bindings.  Command line (ogr2ogr, gdalinfo,
> etc. are functioning as expected).  Specifically, running 'from osgeo
> import gdal', returns:
> File "C:\Python26\ArcGIS10.0\lib\site-packages\osgeo\__init.py__",
> line 17, in
> swig_import_helper
>     _mod = imp.load_module('_gdal', fp, pathname, descritpion)
> ImportError: DLL load failed: The specified procedure could not be found.
> GDAL 1.8 was working wonderfully with ArcGIS.  No environmental
> variables were altered between installations.  Path still contains
> C:\Program Files (x86)\GDAL and GDAL_DATA is stills set to C:\Program
> Files (x86)\GDAL\gdal-data.
> I did try adding the PYTHONPATH variable and setting that to
> C:\Python26\ArcGIS10.0, but no change in the error.
> GDAL1.9 and the python bindings were downloaded from
> http://www.gisinternals.com/sdk/ (the MSVC2010-32bit stable version).
Python 2.6 that comes with ArcGIS 10 was compiled with MSVC2008. That
could be the reason why the bindings aren't working. Try uninstalling
and then installing the matching version.
-marius
> Oddly, the gdal python utilities are functioning.  That is
> gdal2tiles.py for example.
> Any suggestions appreciated.  I assume a PATH error that I am missing,
> but am stumped.  The mailing list archives were sparse on this error...
> Thanks,
> Jay
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120519/26514ba8/attachment.html
