[gdal-dev] Microsoft VS 2010 - build of GDAL 1.9 does not work
James Farrell James.Farrell at delorme.com
Mon May 21 11:23:05 EDT 2012
Thanks, Mateusz
I see the source code now.  I'm linking against gdal.lib.  Shouldn't CPLStringLists's functions be in that library?  Did I somehow build it incorrectly?
Thanks again!
James
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
Sent: Monday, May 21, 2012 11:10 AM
To: James Farrell
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Microsoft VS 2010 - build of GDAL 1.9 does not work
On 21 May 2012 15:41, James Farrell <James.Farrell at delorme.com> wrote:
> I cannot find a definition for Count() anywhere.
> We are not using CPLStringList in our code, but there is other code
> within GDAL that uses it.  Are we supposed to make our own Count()
> function?  Where is this supposed to live?
Look at port/cplstringlist.cpp
Best regards,
Mateusz Loskot, http://mateusz.loskot.net _______________________________________________
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
