[gdal-dev] ogr2ogr shapefile to mapinfo tab: no SRS.
Luca Sigfrido Percich sigfrido at tiscali.it
Fri May 25 06:23:22 EDT 2012
Frans,
try to replace also
SPHEROID["Bessel_1841"
with
SPHEROID["Bessel 1841" in your prj file.
I'm still following the idea that the problem lies with unmatched names
in mitab_spatialref.cpp.
Sig
Il giorno gio, 24/05/2012 alle 14.42 +0200, Frans Knibbe | Geodan ha
scritto:
> Hi Chaitanya,
> The SRS that I am using is a projection (EPSG:28992, to be precise),
> so I think geographic (unprojected) mode is not applicable. I will try
> to update ticket 481.
> Regards,
> Frans
> On 2012-05-24 13:31, Chaitanya kumar CH wrote:
> > Frans,
> > Add the option "-a_srs WGS84" to ogr2ogr command. It should force
> > geographic mode.
> > If that doesn't solve your issue, please go through the discussion
> > on this topic at ticket 481.
> > http://trac.osgeo.org/gdal/ticket/481
> > On Thu, May 24, 2012 at 4:35 PM, Frans Knibbe | Geodan
> > <frans.knibbe at geodan.nl> wrote:
> >         Hello,
> >         I wonder if someone can help me with a nasty problem with
> >         using ogr2ogr to convert shapefile to Mapinfo tab format.
> >         Whatever I try, I can not get the output to have a correct
> >         definition of the SRS. Ogrinfo always reports the output
> >         having a NonEarth SRS.
> >         The input shapefile has a *.prj file. It seems to be ignored
> >         by ogr2ogr. Using the -a_srs option to specify the SRS,
> >         either as an EPSG code or as the name of a file containing
> >         the WKT of the projection also fails.
> >         I have tested this with several versions of ogr2ogr. I do
> >         not notice any difference between versions. The latest
> >         version of ogr2ogr that I could find is "GDAL 2.0dev,
> >         released 2011/12/29".
> >         A web search on this subject leads to several similar
> >         problem descriptions, but I have not been able to find a
> >         solution or even a workaround.
> >         Regards,
> >         Frans
> >         _______________________________________________
> >         gdal-dev mailing list
> >         gdal-dev at lists.osgeo.org
> >         http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Best regards,
> > Chaitanya kumar CH.
> > +91-9494447584
> > 17.2416N 80.1426E
_____________
PRIVACY
Le informazioni contenute in questo messaggio sono riservate e confidenziali. Il loro utilizzo e' consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo dal Suo Sistema e a distruggere le varie copie o stampe, dandone gentilmente comunicazione all’indirizzo mail del mittente. Ogni utilizzo improprio e' contrario ai principi del D.lgs 196/03 e alla legislazione europea (Direttiva 2002/58/CE).
PRIVACY
