[gdal-dev] __main__.gdal_config_error when trying to install gdal
Chao YUE chaoyuejoy at gmail.com
Sun May 27 14:22:41 PDT 2012
Dear Even,
Did you use ubuntugis before? I have one question, I followed the
instruction to add ppa:gwibber-daily/ppa to my repository.
Then I use sudo apt-get update to install the packages. Yet can I install
only one package (let's say gdal)?
I do a little search online and some people say I can use directly
sudo apt-get install gdal
but it reports E: Unable to locate package gdal, I cannot find the package
in my Ubuntu software center either...
thanks,
Chao
2012/5/27 Even Rouault <even.rouault at mines-paris.org>
> Selon Chao YUE <chaoyuejoy at gmail.com>:
> > Thanks Etienne, then I guess I will have the problem of python version? I
> > guess I will need a virtual python environment (or something) if I need
> > python 3 for newer versions?
> No, the page tells that Python 3 is supported since GDAL 1.7, but not that
> it is
> required. Python 2.X is still supported.
> > best,
> > Chao
> > 2012/5/27 Etienne Tourigny <etourigny.dev at gmail.com>
> > > Hi chao
> > > you should install gdal using the ubuntugis (stable or unstable)
> > > repository . 1.6.3 is really old, plus you shouldn't install the
> > > debian packages on ubuntu.
> > > see:
> > > https://launchpad.net/~ubuntugis
> > > http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries
> > > If you really have to build it see:
> > > http://trac.osgeo.org/gdal/wiki/BuildHints
> > > Etienne
> > > On Sun, May 27, 2012 at 5:39 PM, Chao YUE <chaoyuejoy at gmail.com>
> wrote:
> > > > Finally I managed to install gdal 1.6.3 using a debien package (and I
> > > have
> > > > to install libgdal1-1.6.0 before ). But I read from
> > > > http://trac.osgeo.org/gdal/wiki/GdalOgrInPython
> > > > saying that from version 1.7.0, python 3 is needed.
> > > > thanks et cheers,
> > > > Chao
> > > > 2012/5/27 Chao YUE <chaoyuejoy at gmail.com>
> > > >> Dear all,
> > > >> I am new to gdal and when I try to install it on my ubuntu
> computer, I
> > > >> have the following error. It occurs either with pip or with manual
> > > python
> > > >> setup.py build.
> > > >> could anyone give me some clue on this problem? thanks in advance.
> > > >> Chao
> > > >> chaoyue at chaoyue-Aspire-4750:~/python/python_lib/build/gdal$ sudo
> python
> > > >> setup.py install
> > > >> [sudo] password for chaoyue:
> > > >> running install
> > > >> Checking .pth file support in
> /usr/local/lib/python2.7/dist-packages/
> > > >> /usr/bin/python -E -c pass
> > > >> TEST PASSED: /usr/local/lib/python2.7/dist-packages/ appears to
> support
> > > >> .pth files
> > > >> running bdist_egg
> > > >> running egg_info
> > > >> writing GDAL.egg-info/PKG-INFO
> > > >> writing top-level names to GDAL.egg-info/top_level.txt
> > > >> writing dependency_links to GDAL.egg-info/dependency_links.txt
> > > >> Traceback (most recent call last):
> > > >>   File "setup.py", line 267, in <module>
> > > >>     ext_modules = ext_modules )
> > > >>   File "/usr/lib/python2.7/distutils/core.py", line 152, in setup
> > > >>     dist.run_commands()
> > > >>   File "/usr/lib/python2.7/distutils/dist.py", line 953, in
> run_commands
> > > >>     self.run_command(cmd)
> > > >>   File "/usr/lib/python2.7/distutils/dist.py", line 972, in
> run_command
> > > >>     cmd_obj.run()
> > > >>   File
> "/usr/lib/python2.7/dist-packages/setuptools/command/install.py",
> > > >> line 73, in run
> > > >>     self.do_egg_install()
> > > >>   File
> > > >> line 93, in do_egg_install
> > > >>     self.run_command('bdist_egg')
> > > >>   File "/usr/lib/python2.7/distutils/cmd.py", line 326, in
> run_command
> > > >>     self.distribution.run_command(command)
> run_command
> > > >>     cmd_obj.run()
> > > >>   File
> > > "/usr/lib/python2.7/dist-packages/setuptools/command/bdist_egg.py",
> > > >> line 172, in run
> > > >>     self.run_command("egg_info")
> run_command
> run_command
> > > >>     cmd_obj.run()
> > > >>   File
> > > "/usr/lib/python2.7/dist-packages/setuptools/command/egg_info.py",
> > > >> line 179, in run
> > > >>     self.find_sources()
> > > >>   File
> > > >> line 254, in find_sources
> > > >>     mm.run()
> > > >>   File
> > > >> line 308, in run
> > > >>     self.add_defaults()
> > > >>   File
> > > >> line 332, in add_defaults
> > > >>     sdist.add_defaults(self)
> > > >>   File
> "/usr/lib/python2.7/dist-packages/setuptools/command/sdist.py",
> > > >> line 191, in add_defaults
> > > >>     build_ext = self.get_finalized_command('build_ext')
> > > >>   File "/usr/lib/python2.7/distutils/cmd.py", line 312, in
> > > >>     cmd_obj.ensure_finalized()
> > > >>   File "/usr/lib/python2.7/distutils/cmd.py", line 109, in
> > > >> ensure_finalized
> > > >>     self.finalize_options()
> > > >>   File "setup.py", line 164, in finalize_options
> > > >>     self.gdaldir = self.get_gdal_config('prefix')
> > > >>   File "setup.py", line 144, in get_gdal_config
> > > >>     return fetch_config(option)
> > > >>   File "setup.py", line 97, in fetch_config
> > > >>     raise gdal_config_error, e""")
> > > >>   File "<string>", line 4, in <module>
> > > >> __main__.gdal_config_error: [Errno 2] No such file or directory
> > > >> Chao YUE
> > > >> Laboratoire des Sciences du Climat et de l'Environnement (LSCE-IPSL)
> > > >> UMR 1572 CEA-CNRS-UVSQ
> > > >> Batiment 712 - Pe 119
> > > >> 91191 GIF Sur YVETTE Cedex
> > > >> Tel: (33) 01 69 08 29 02; Fax:01.69.08.77.16
> > > > Chao YUE
> > > > _______________________________________________
> > > > gdal-dev mailing list
> > > > gdal-dev at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Chao YUE
Chao YUE
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120527/ee5ed3ce/attachment-0001.html>
