[gdal-dev] Heads-up re: poppler/pdf on Windows
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon May 28 05:01:16 PDT 2012
On 12-05-25 6:16 PM, Even Rouault wrote:
> Hi Jeff
> Or use trunk or latest state of 1.9 branch ;-) . 1.9 branch has been updated
> with poppler 0.20 support just a bit after 1.9.1, but it will be in 1.9.2. See
> http://trac.osgeo.org/gdal/ticket/4668 if you need to patch. For 0.20 support
> you need to uncomment all the POPPLER_ lines in nmake.opt (including the new
> POPPLER_0_20_OR_LATER = YES)
> 0.18 should work too. At least I've tested it successfully on Linux.
> Best regards,
> Even
Hi Even,
Thank you, this does explain my frustrations with 1.9.1 :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
