[gdal-dev] GDAL with mdb support on Ubuntu 12.04
Luca Casagrande luca.casagrande at gmail.com
Mon May 28 06:05:39 PDT 2012
Il 28/05/2012 14:55, Even Rouault ha scritto:
>> If I try without it, I have got this error message:
>> --with-java=yes --with-mdb=yes
>> configure: error: "--with-jvm-lib must be specified."
> Luca,
> I've just installed a i386 ubuntu 12.04 VM and installed openjdk-7-jdk in it.
> "./configure --with-java --with-mdb" just works out of the box, so I'm wondering
> if there isn't something special (or wrong) with your setup. Does
> "/usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java -server -version" works for you
> ? If you look in the generated config.log, how do the lines with "jvm" in them
> look like ?
> Best regards,
> Even
Hello Even,
my system is a amd64 so don't know if this can matter.
Related to you suggestions:
luca at scummbar:~$ /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java -server
-version java version "1.7.0_03"
OpenJDK Runtime Environment (IcedTea7 2.1.1pre) (7~u3-2.1.1~pre1-1ubuntu2)
OpenJDK 64-Bit Server VM (build 22.0-b10, mixed mode)
Hire is the full config.log:
http://ubuntuone.com/3HlRqtTs0nu4NeguX2eIG4
Thanks for you help
L.
Luca Casagrande
http://www.lucacasagrande.net
