[gdal-dev] proj.4 +b parameter has different precision on i386 vs. amd64
Tue May 29 11:58:18 PDT 2012
On Tue, May 29, 2012 at 7:38 AM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Hi list,
> It seems that the +b parameter of Proj.4 strings generated by gdal can
> have different precisions, dependent on the architecture (i386 vs.
> ams64) for various linux flavors and gdal versions (1.6 - 1.9).
> The CRS from EPSG:4131 can have slightly different values: (
> +b=6356075.413140239 vs. +b=6356075.41314024 )
> i386:
> +proj=utm +zone=48 +a=6377276.345 +b=6356075.413140239
> +towgs84=198,881,317,0,0,0,0 +units=m +no_defs
> amd64:
> +proj=utm +zone=48 +a=6377276.345 +b=6356075.41314024
> ==> Can this happen with other values?
Etienne,
I imagine it can, though this value is particularly
sensitive to it since it is computed.
> ==> Is it an artifact of the calculation of the semi-minor axis from
> semi-major and inv-flattening in ogr_srs_proj4.cpp ?
> ==> Is this a bug?
In my opinion it is not a bug.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
