[gdal-dev] ogr ODBC problem
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Wed May 30 13:09:27 PDT 2012
Hi!
I use this command to get the tables from an ODBC connection
ogrinfo ODBC:User/Pwd at DNS
The connection is succesful but I get this error several times
ERROR 1: No column definitions found for table '�s���s!.�����������',
layer not usable.
I used OGR ODBC for several months from a Windows server to a MSSQL server
Now I'm migrating to linux and accessing the same MSSQL SERVER and I get
this error.
Note that if I connect with isql, I can connect and query the database
without problem.
So the problem really seems to be with OGR
What can cause this No column definitions found for table error
And why the table name looks like this  '�s���s!.�����������',
thanks
steve
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120530/1cd9fcec/attachment.html>
