[gdal-dev] ogr ODBC problem
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed May 30 14:06:51 PDT 2012
On 12-05-30 5:09 PM, Steve.Toutant at inspq.qc.ca wrote:
> Hi!
> I use this command to get the tables from an ODBC connection
> ogrinfo ODBC:User/Pwd at DNS
> The connection is succesful but I get this error several times
> ERROR 1: No column definitions found for table '�s���s!.�����������',
> layer not usable.
> I used OGR ODBC for several months from a Windows server to a MSSQL server
> Now I'm migrating to linux and accessing the same MSSQL SERVER and I get
> this error.
> Note that if I connect with isql, I can connect and query the database
> without problem.
> So the problem really seems to be with OGR
> What can cause this No column definitions found for table error
> And why the table name looks like this  '�s���s!.�����������',
Hi Steve,
I was just debugging an ogrinfo command for MS4W/Oracle, and was
reminded of the trick to show more debug info at the commandline:
   set CPL_DEBUG=on
I'm going to keep that one in my back pocket from now on.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
