[gdal-dev] RE [Polluriel potentiel] Re: ogr ODBC problem
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Thu May 31 09:11:10 PDT 2012
Thanks Brent for your answer.
But ....view's primary key?
I'm missing something here...What do you mean by that? Do you mean a
column with a unique id in the view?
There is no such column in my view. Is ogr now needs a unique id in a
view? Because it was working before I migrate to linux with a recent
vertsion of gdal.
Also, My problem is before using CONNECTIONTYPE OGR
    CONNECTION "<OGRVRTDataSource>
A simple ogrinfo like this
ODBC:username/password at WebMapDSN,v_MyPoints
Gives me the error OGR_ODBC: Table ?s???s!.????????? has no identified FID
column.
Thanks in advance
Steve
Brent Fraser <bfraser at geoanalytic.com>
2012-05-31 10:49
A
cc
gdal-dev at lists.osgeo.org
Objet
[Polluriel potentiel]  Re: [gdal-dev] ogr ODBC problem
Steve,
  Here's a snippet from a MapServer map file I used to access a
non-spatial MS SQL server via OGR+VRT+ODBC:
    TYPE POINT
    CONNECTIONTYPE OGR
        <OGRVRTLayer name='v_MyPoints'>
<SrcDataSource>ODBC:username/password at WebMapDSN,v_MyPoints</SrcDataSource>
           <SrcSQL>
            SELECT * FROM  v_MyPoints
            WHERE  PropertyID=%PropertyID%
        </SrcSQL>
        <FID>PointID</FID>
        <GeometryType>wkbPoint</GeometryType>
        <GeometryField encoding='PointFromColumns' y='SurfaceLatitude'
x='SurfaceLongitude'/>
        <LayerSRS>NAD83</LayerSRS>
        </OGRVRTLayer>
    </OGRVRTDataSource>"
    PROCESSING "CLOSE_CONNECTION=DEFER"
    DATA "v_MyPoints"
In my case I was able to use the view's primary key as the FID.  Hope this
helps...
Best Regards,
Brent Fraser
On 5/31/2012 7:48 AM, Steve.Toutant at inspq.qc.ca wrote:
Thanks Jeff
I got now OGR_ODBC: Table ?s???s!.????????? has no identified FID column.
I found that several users had this problem but found no solution. I don't
have write access to this MSSQL server.
I'm connecting via ODBC to a non spatial table, but it contains latitude
and longitude information. I will use it to define a OGRVRTDataSource and
create geometry from point.
Any clue on what I can do?
thanks
steve
Jeff McKenna <jmckenna at gatewaygeomatics.com>@lists.osgeo.org
Envoyé par : gdal-dev-bounces at lists.osgeo.org
2012-05-30 17:06
A
cc
Objet
On 12-05-30 5:09 PM, Steve.Toutant at inspq.qc.ca wrote:
> Hi!
> I use this command to get the tables from an ODBC connection
> ogrinfo ODBC:User/Pwd at DNS
> The connection is succesful but I get this error several times
> ERROR 1: No column definitions found for table '?s???s!.???????????',
> layer not usable.
> I used OGR ODBC for several months from a Windows server to a MSSQL
server
> Now I'm migrating to linux and accessing the same MSSQL SERVER and I get
> this error.
> Note that if I connect with isql, I can connect and query the database
> without problem.
> So the problem really seems to be with OGR
> What can cause this No column definitions found for table error
> And why the table name looks like this  '?s???s!.???????????',
Hi Steve,
I was just debugging an ogrinfo command for MS4W/Oracle, and was
reminded of the trick to show more debug info at the commandline:
  set CPL_DEBUG=on
I'm going to keep that one in my back pocket from now on.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120531/3b97a519/attachment-0001.html>
