[gdal-dev] GDALGetMaskFlags() bug with GTOPO30 data
Craig Bruce csbruce at cubewerx.com
Thu May 31 12:41:40 PDT 2012
Even Rouault <even.rouault at mines-paris.org> wrote:
> If you do GetMaskBand().GetMaskFlags(), then it will return 0x1, since
> the mask band itself has no mask.
Oops, that is what I did.  Thanks.
Dr. Craig S. Bruce        | Ph 819-771-8303 x205 |             CubeWerx Inc.
Senior Software Developer |   Fax 819-771-8388   |  Gatineau, Québec, Canada
csbruce at cubewerx.com      |  http://csbruce.com/ |  http://www.cubewerx.com/
                 "Ogden's Law: The sooner you fall behind,
                    the more time you have to catch up."
